Anyone using a Tune2Air
http://www.ebay.com/sch/i.html?_odkw...+C300&_sacat=0
YMMV!
Here's a better link.
http://a.co/72ExZ5j
All you need is the unit. It already has a 30pin connector on one end. Plug and play literally
https://www.amazon.com/ViseeO-WMA300...words=tune2air
Thanks Adi ! Im gonna go with that one. You have it as well ? What do you think of it ?
That I am not sure. I guess Mercedes probably changed the set up along the way. I currently have a older gen Ipod connected to the factory 30-pin cable
I'm still using the CarPro I purchased in 12/2015.
Try each model. Amazon has a great return policy as you can see in my thread
A reminder.. read your owner' manual. The following is from a C300 2011 manual. The sound was low and poor until I performed the following steps to "Boost" the sound, which solved the problem/
COMAND in your vehicle may differ. May or may not apply.
Increasing the volume using COMAND
It may be the case that a device which is connected as an external audio source seems quieter or louder in the vehicle, or that the usual maximum volume cannot be achieved. The volume of some devices can be set
separately. In this case, start at a medium volume and then raise it slowly. This enables you to hear if the system can play the music without distortion even at high volumes.
Select Volume in the AUX display by turning the COMAND controller and press to confirm.
A menu appears. The dot indicates the current setting.
Select Standard or Boost and press to confirm.
Standard: the volume of the external audio source is adjusted to a standard value.
Boost: the volume of the external audio source is raised by approximately 10 dB.
Good luck!
