problem question
Old Mar 3, 2017 | 04:07 PM
acela11's Avatar
2012 c350 sedan
problem question
I just started my car and the dash lit up like a christmas tree. the abs, engine and traction control lights are staying on. Can this be caused by the battery going bad? thanks
Old Mar 3, 2017 | 04:47 PM
Alfadude's Avatar
2012 C300 4Matic
It could. However, it could also be a host of other things. If the car was running perfectly fine then all of a sudden this issue came up out of the blue the battery would at least be the easiest and simplest place to start. Cars today are extremely sensitive to the correct voltage and batteries can go out without warning.
Good luck! I hope you get it sorted quickly.
Old Mar 3, 2017 | 05:29 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Did you try turning it off and restarting? If not, you can put the car in dyno mode to see the battery voltage.
Old Mar 3, 2017 | 05:31 PM
tommiett's Avatar
2015 C350 Sport
Check the alternator - even a bad belt could cause this issue. Probably battery/alternator issue.
Old Mar 3, 2017 | 05:36 PM
acela11's Avatar
2012 c350 sedan
i managed to get rid of all but engine light by removing negative battery cable, ill drive the car for awhile and see if engine light goes out. btw, how do u put the car in dyno mode to check the voltage? thanks
Old Mar 3, 2017 | 05:39 PM
LILBENZ230's Avatar
I don't know offhand, you'll be able to find that in a search and probably a video tutorial on youtube.
Get the check engine light code read and post it up.
Old Mar 3, 2017 | 05:40 PM
acela11's Avatar
2012 c350 sedan
thanks, just watched the video
Old Mar 6, 2017 | 10:27 AM
acela11's Avatar
2012 c350 sedan
just came from dealers, no code for engine light. they have to change speed sensors for the other lights
