removing carpet
Old Apr 11, 2017 | 06:20 PM
khorissian's Avatar
Mercedes c300
removing carpet
I would like t now how I can remove the carpet under the front seat and between front an back seats. I need to clean them because of a bad spill.
Old Apr 11, 2017 | 09:47 PM
superangrypenguin's Avatar
A car
You mean underneath the seats? You'd have to remove them.
Old Apr 11, 2017 | 09:51 PM
ItalianJoe1's Avatar
2003 CL 600
The front sections in the footwells can be removed by removing the door sill plastics and the gas pedal on the drivers side, along with the under dash plastics, then the carpeting can be pulled out from under the console and worked out of the car.
The secondary pieces under the actual seats require removal of the seats, but once they are out the carpeting can be easily removed, just work it out from under the edges.
You can remove the console fairly easily on that car if you need more access but it shouldn't be necessary just to pull the carpets
Old Apr 12, 2017 | 06:13 PM
BobInDenver's Avatar
2013 C300 4Matic
Life saving site right here:
http://www.pelicanparts.com/techarti...Index-W204.htm
Everything you need or want to do to your vehicle with clear instructions and pics. ;-)
