C200 2012 transmission valve body fault
Old Apr 16, 2017 | 05:33 AM
Rami1212's Avatar
Mercedes c200 CGI 2012
Question C200 2012 transmission valve body fault
I have had my C class checked into the dealer workshop as the engine light appearing on my dash bored and the result is my Transmission Valve body needs replacement, however I searched for a bit and found that there might be a fault of the conductor plate and can be replaced with the 2nd and 3rd generation of the 7 gear model , however I am not sure of my gear generation and I would like to know if my car model conductor can be replaced or repaired without replacing the whole Valve,
appreciate your input and advises into the options I can try ...
Old Apr 18, 2017 | 03:53 AM
Rami1212's Avatar
Originally Posted by Plutoe
To confirm that correctly you need to post the VIN
PS: Many folks confuse the terminology--valve body and conductor plate--do you know the difference and what was printed on the dealer invoice!!
Thanks Plutoe, however I didn't get a report neither an invoice for my car yet , it was the mechanic first diagnose that mostly the transmission valve body needs replacement and asked me to check-in the workshop and pay 300 bucks to have it investigated further (which I did not do ). later I researched a bit on the issue and found that usually the fault happens in the speed sensor placed on the conductor plate and can be replaced without having to replace the TVB.
Please give your opinion on the best course of action to be taken in my situation ?
here is my Vehicle VIN if it could help WDDGF4JB7CA534184
as for the Part number as I mentioned I don't have that yet.
Old Apr 18, 2017 | 10:33 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Check it at the dealer. Search google maps for indy mechanics with good reviews; many of them diagnose for free. Doesn't mean you'll have to use them to repair. If you get a lot of people saying its that thing you can be more confident that that is the problem.
