How to see if a dealer has set tranny fluid to correct levels?
I'm worried b/c the dealer has never done a TQ drain and fill as part of this service. How can I ensure the tech puts in the right amount of fluid given the fact that they will be also draining the torque converter for the first time? (since they and other dealers have skipped that step) (step #6 in the WIS)
Is there something that they can produce? How can I seek verification other than their word? Thanks
Draining the converter is simple just have to slowly rotate the crankshaft with a wrench while someone looks to see when the converter drain plug comes in to view at the 6 o’clock position so a Allen key can un screw it.
Approx 2 litres of fluid in the converter and they should use new washers on both of the drain plugs, I did mine a home and the filter and yes a lot of very dark coloured fluid drained out well worth the effort.
Which fluid would a 2012 GL450 use, about how much and is finding a fluid with the correct specs, of any brand, acceptable? I hate to get sucked into MBs plan for us DIYers.
