What's the latest version of the COMAND firmware?
The car has been very well maintained but I don't know whether the firmware is likely to have been updated since the car was bought during normal services.
Alternatively, you can buy the update CD second hand. Apparently it can take a couple of hours during which time the ignition has to be on. Some people have attempted to do this with pirated disks and ended up bricking their COMAND. This has also happened in some cases with genuine disks where the disk capacity wasn't sufficient to apply the update so be careful if you aren't sure what you are doing.
The Audio20, NTG4, NTG4.5 and NTG4.7 are diferent systems, with there own firmware / operative system!
The firmware can only be update at the dealer, by paying or within garanty. Updating the firmware is mandatory for example in NTG4 updating to V12 or newer maps navigation versions...
There is someone that says the update process takes about 2-3 hours and can be done at home. That is just for updating MAPS for NTG4! Not the firmware!
You can update maps for NTG4.5 and NTG4.7 at home but need to buy to the dealer a specific code!
So, firmware is one thing, updating the maps is another thing!
Just go by the dealer and ask them to update the firmware, not the maps! It takes 30 minute...
You can install the maps with any firmware version! The problem is that if you have an older firmware version (cant say which), after updating to v12 or newer, after you turn on the command, there will be a message like "activating navigation...". And that message will stay forever till you update the firmware. Everything will work except navigation!
This is true for NTG4. Cant say for NTG4.5 or NTG4.7!
Updating the firmware on the dealer is cheap! It cost me 50 €.
But cant compare firmware version between comand units because it differs on internal, region, etc..
https://mbworld.org/how-tos/a/merced...et-menu-388886
Turns out I'm on BLD-NTG47 6.23
