Transmission dipstick
My understanding is that there's a transmission dipstick for the fluid level but it's covered by a plug. I know we can buy the dipstick by providing a part number, but where the [expletive] is the dipstick?
I can't find it for the life of me!! Danke
On my 5 speed ATM you remove the cap by first breaking the end off the little red tab & pushing the tab down.
I kept the long piece which goes down & locks the cap, to use again.
There is no dipstick , you will have to buy one. MB would not sell me one so I bought it elsewhere. Try googling or Ebay.
There is no dipstick(on w204). Fluid level is maximized by an overflow tube attached to the bottom of the pan. Read the sticky. Much info. there. Older models have a tube from engine compartment to transmission. Yes, on those cars you must purchase a dipstick.
Sorry, sticky, where?
Apologies for the idiotic post. Just for the record, mine's a 7g tronic (non plus). Thanks!
superangrypenguin (05-03-2017)
I would conclude if you had a dipstick tube in your engine bay with a locked cap that your ATM was dip stick compliant ?
Yeah, so no dipstick which would mean then that there's no way for me to check.
I suspect my guess above is right, sigh
Thankfully it's still easy to check. The standpipe arrangement is brilliant. Crack the drain plug with the engine running and if nothing comes out, you're low.
If you have a W204, you don't have one. I've been in and around the engine and transmission and if it's there I managed to miss it the last 9 years.
The SA told me that they know how much they have pumped out, so they know how much to pump back in. Is this true?
Adapters are available on eBay, Amazon, etc. for about 10 bucks, pump for about 5. And since it all happens at the bottom, you don't get fluid getting all over the transmission as you would with traditional fill plugs that go on the side.
Give it a shot! Our cars even have a TC drain plug which a lot of autos don't have.
Only seems crude, but actually quite elegant. If you want to top it off just run the car and pump .5 quart through the drain plug. When the overflow slows to a trickle, plug it up and you're done.
Just concerned I may cause a problem which is overfilling the damn thing. Thanks
I doubt it. It will be very clear when the fluid is gushing out (overfilled) vs a trickle when you fill it correctly. It will be very obvious when it transitions from one to the other.
Note of caution. When checking or adding fluid car must be perfectly level and fluid at correct temp. with infra red thermometer.
the fluid needs to be at specified temperature (45c for most), and the "dribbling out" rate is rather subjective. Using a IR thermometer really isnt appropriate either, so bust out your STAR or iCarSoft. While this isnt out of the ordinary for transmission fluid procedures its hardly optimal, and certainly could not be any further from 'elegant'.
unless the transmission is leaking there's no reason to go poking around to 'check it'. if its not functioning right then checking the fluid level isnt going to make it better.
superangrypenguin (05-06-2017)
errrr not so fast.
All procedural details aside, the system is absolutely elegant. But that, as you say, is subjective.
lol there's that word again. I will do it. I've done it on many different vehicles types and I can tell you that you are drinking way too much Benz Kool-Aid if you call that "elegant".
Elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant elegant.
Just kidding.
Lol cheers, agree to disagree.
Just kidding.
