Coolant and Battery Questions
How long can I drive with the initial coolant liquid and top it up before actually replacing the full amount? My car is 5 years old and I was wondering about the coolant...
Same question goes for the battery... how do I know that the battery has to be replaced before it actually dies? Is there a way to know?
15 years for the coolant.
Battery - every 5 to 7 years.
Thank you for your answer.
15 years is so much, that's a relief
at least I won't have to pay for this.
As to the battery, is there a way to know that it is going to die soon?
Have a battery expert do a load test. They are usually free. My battery is now 10 years old but has been used in ideal conditions.
Always top up the with MB coolant & demineralised ( found in supermarkets for ironing) water 50:50 ratio.
As far as battery goes, your guess is as good as mine. It really comes down to a function of driving style, temperature of operation (hot days kill batteries. Cold days require a better battery). So if you live in a place that's hot as hell in the summer and cold as hell in the winter - replace more often.
I'm at year 5 going to year 6 this winter. I'm probably going to swap my battery for the first time for the life of this car. Only $300 installed - not worth gambling over.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
VERIFIED with my solar and even had 2 other friends who own auto shops verified my load test.
battery was giving trouble starting .
here is my tester.
http://www.ebay.com/itm/New-SOLAR-40...oAAOSwTuJYvdou
LOL
here is my tester.
here is my tester.
By load test - usually one refers to the shi*y $20 testers you can buy are your local parts store or the 'free tests' done by dealerships or your local part store - those are generally useless.
Actually, on both fronts yes they are great tests. Battery giving trouble starting = signs of a new battery, and yes, the ONLY battery test that I consider valid is one that tests CCA, so yes, you're using a great tester.
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
I have the same solar battery tester as this guy (measures CCA).
Fast forward to 3:00 to see how to use it.
