A140 R/H headlamp beam not working
A140 Elegance
Right Hand main beam headlight is not working. Bulb and fuse both okay. No voltage getting through to it on connecter to headlamp unit. Is there a relay somewhere that could be faulty?
A140 Elegance
Relays
Have followed the wiring back to where it goes in to the relay box. Removed water reservoir and got cover off. Relays are set in there very deep! Don't even know if there is a relay for headlamp beam? And even if there is, would they have used two separate relay contacts, one for each lamp????
