New wheels (:
Old Jun 29, 2017 | 04:27 AM
PotatoMage's Avatar
W166 GLE63s AMG
New wheels (:
New wheels on the LCI C350, need wider rear tires next year when these ones run down though. 255 on a 9.5" wide rim is very stretched....
Anyone have experience with a 275? The wheel is pretty close to suspension components and I'm hoping if I switch to 265 or 275 (preferably 275) that it will not rub.
Wheel and tire specs:
Fastco Fast FC04 with Continental ExtremeContact Sport tires
Front: 19" x 8.5" ET45 225/35/19
Rear: 19" x 9.5" ET45 255/30/19
Paid about $2500CAD for rims + tires mounted, balanced and shipped to my door.
Also got a CF Layover for the start button (:
New wheels (:-vwyj5tjl.jpg
Before VS After
New wheels (:-ngsawldl.jpg
Before VS After 2
New wheels (:-cuphbuxl.jpg
New wheels (:-9eukohnl.jpg
New wheels (:-pn0ghksl.jpg
New wheels (:-wjmvtxul.jpg
New wheels (:-f8fcja4l.jpg
CF Start Button pics
New wheels (:-8bus6jzl.jpg
New wheels (:-tfudbzel.jpg
Old Jun 29, 2017 | 12:46 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Nice!
A lot of people have told me 275 won't work, but I would do some research because I vaguely remember seeing something.
I plan on getting 265's on my 9.5 when I buy my wheels in august.
Old Jul 1, 2017 | 11:19 AM
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
Originally Posted by PotatoMage
...need wider rear tires next year when these ones run down though. 255 on a 9.5" wide rim is very stretched....
While it may appear streched, 255mm is equal to 10 inches and is also within the tires recommended wheel size. WHen I had the stock tires, 9.5 did look too wide, however once I transitioned to the Michelin Pilot Super sports, it looked very natural due to the wider shoulders of the tire.
Old Jul 1, 2017 | 03:10 PM
97 GSX 97's Avatar
2014 C300 Sport
Looks good. The car is begging for at least lowering springs now.
Old Jul 1, 2017 | 05:13 PM
MurderedC300's Avatar
2011 C300 4MATIC SPORT
I have 275's on my Avant Garde M590 wheels that are 19x9.5 +48 offset with 275/30/19 Michelin Pilot Super Sport tires in the rear. I had slight issues with rubbing when I first got them mounted so I had a friend use a fender roller to slightly pull the rear fender lips out which solved my problem. I've heard the Michelin pilot super sports are a much wider "Boxier" tire than other brands that do have such a square or flat tread surface. If you search for which tire has a narrower pattern than the Michelin pilot super sports you should be fine.
Old Jul 2, 2017 | 12:33 AM
edgalang's Avatar
+1 To add to that, I can confirm that 265/35/18 on 18x9.5+45 will rub on the rear even on stock height with the Michelin Pilot Super Sports.
Old Jul 2, 2017 | 04:16 PM
Adi-Benz's Avatar
+45 and SS are definitely going to rub.
+48 and SS at 265's will be close; 275's will sometimes rub
+48 and slimmer tires at 265 should clear, 275 idk
Old Jul 11, 2017 | 09:10 PM
PotatoMage's Avatar
W166 GLE63s AMG
Thanks for the input guys! Yeah I went with conti's cause they have a rounder sidewall than michelins. However now that I can physically see the fitment as opposed to estimating, I can say that 265 conti's will definitely fit without rubbing. I'm not so much worried about rubbing against the wheel well but more against suszpension components.
