High Pressure Fuel Pump replacement
It seems to be a common failure on these cars.
In order to make my decision if they say no coverage has anyone here done the pump on their own? Reconditioned ones go around $300 and new seems to be around $800-$1,000+.
I see it's located under the rear seat.
Good luck on getting it covered, you never know.
For the record for this forum, for naysayers who say that my whining about DI cars is unwarranted...
Here's one case. That one HPFP replacement bill costs more than all the fuel savings for the life of that car because it is DI injected vs PFI cars.
Ha.
Ha.
The Internet is full of stories about the C-Class and fuel cuts under WOT. Sometimes replacing the pump doesn't seem to fix the issue.
It may last the life of the car as is but it's scary when you pull out into heavy traffic and the car's power just drops.
Scanning with torque shows a P0002 code. Which is a generic fueling code.
More parts usually indicate a higher probability of something needing replacing in the vehicle.
It's simple math and science. 'tis all.
"The technology in question involves the use of more parts and technologies". PRICELESS
. Piezo scares ya? HPFP? LOFL!
Freindly advice, more reading, less typing.
Yeah, replacing a HPFP is definitely more infrequent than replacing traditional fuel pumps.
And it costs less, much much less.
Friendly advice, learn what you're actually talking about.
Although he would benefit a lot financially since I do all my repairs at his private shop, he has so many stories about DI engines he works on at the dealership (non-return valves (check valves), left and right secondary chain tensioners, high-pressure fuel pumps, and the piezo injectors) and he always says that yes that engine might be very smooth and fuel efficient, but one trip to the dealership and all those fuel savings are negated by the expensive bill.
The reality is that we'll simply have to stick to either a) bending over at the dealership or b) buying extended warranty direct from the manufacturer. Since I only know the C class extended warranty costs, here in Canada, for a 7 year warranty with the 7th year only covering powertrain and a total of 160,000km, it's only around $2500. That's one HPFP repair or one and a bit carbon cleanings etc (so well worth the money)
Direct injection allows car makers to get darn good fuel mileage and darn good horsepower, and 99.999% (i'm guessing) of people don't even know what direct injection is, let along the problems associated with it. As educated buyers, we do, but there's really nothing we can do about living with these cars, cost wise, than to ensure we're covered with warranty.
Too bad cars these days are like young hot blonds (cheap and disposable)
<--not meant to be an insult to anyone, just a dumb online joke. All the talk over the last 2 days about direct injection and having to dispel the myths shared by some on this board have made me want to stick to my existing W204 since it's a reliable ol' chap. Silver lining I guess
Thanks for saving me $100k + on a new car
But, introduces a new point of failure..and it's not a cheap part. Fuel savings for having a turbo will never be more than a turbo repair/replacement job.
It was $1600 but the good will warrantied it, since we only had 4k miles since we bought it
that would have been a stiff out of pocket on a new car to us..
