2ND CATS DELETE + X PIPE
Do this. Remove the large resonator (where the x-pipe is in the picture) and leave the secondary cats/resonators alone. Makes it louder, sounds good, no highway drone
Should've done it this way.
Xpipe alone hardly did anything.
EVERY W204 Sounds different. Even if you have same car. Marko's for example, was just X-pipe, just like Funk's, and they both made a big difference.
Others, not so much. Could be US/CA market? OBVIOUSLY engine size will matter but that is a given.
No matter what, it seems that no one can expect the exact same result with 2 comparable w204's.
I had just an x-pipe and Magnaflow straight-through mufflers for a while. When I deleted the secondary cats it made the exhaust note more screamy/raspy on the higher end. I absolutely love it.
I had highway drone with just an x-pipe in place of the resonator and straight-through Magnaflow mufflers.
Went back to stock mufflers and deleted the "2nd cats" and I'm enjoying a no-drone exhaust with a mild but louder than stock sound.
