W204 Fog light replacement problem
good day i currently have a W204 C class 2009 model . i opted to switch out the fog lights and replaced them with halogens.I had error cancellors installed and now after about a year the left permanently has stopped working and now the right and the error chancellors do no work. any advice?
The electrician says the error chancellors work fine as well as the bulb but it seems as if power is not going to the fog
the stock bulbs are halogens. do you mean you switched to HIDs?
SPONSOR/MBworld Guru
Ballast issue maybe? Best thing to do is to try swapping components left and right until the issue switches sides.... then you know exactly what components is faulty.
