Fuel temperature too hot
Old Aug 26, 2017 | 06:24 AM
Dacian Micula's Avatar
w204 avantgarde
Hi to all.
I have a problem related to fuel temperature as you can see in the attached image.
The fuel temp is at 60 celsius, not in the range of max 50 celsius. This cause a rough idle to my car.
Quantity control valve will inject mere fuel.
I tested on star the sensor and tested the pipe from the fuel tank temperature and both is 60 celsius.
Can someone bring an ideea why this is happening?! What can cause the temperature of fuel be so high?
I have no other error on star. The car is c220, cdi engine with 170 hp 2007 year w204.
Thank you in advance.
Old Aug 26, 2017 | 08:13 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Not real familiar with MB diesels but have had experience with other marks/brands. If your Benz has a fuel cooler would check to see that it is not clogged. My most common cause of seeing high fuel temps on my Cummins has been a clogged fuel filter(s).....has yours been changed on schedule?
Old Aug 26, 2017 | 08:20 AM
w204 avantgarde
Thank you for your reply.
I changed the fuel filter 500 km ago with oil and other filters... i had seen an improvment of idle but still rough.
If there is a fuel cooler I don't know where is located... I can't find it. Does somebody know where to search for it?
Old Aug 26, 2017 | 10:24 AM
gamma300C's Avatar
If you Google CDI 220 fuel cooler there are many posts with pictures and location posts. The fuel cooler cools fuel as it returns to fuel tank so not really optimistic this the cause of your problem unless you only have the higher fuel temps after running the car hard for quite a while or with a near empty tank.
Would be useful to know where the temp sensor is located...
Old Aug 26, 2017 | 10:56 AM
w204 avantgarde
I know the location of fuel temp sensor on w204...
the fuel temp before the fuel filter coming trom the tank is 60 celsius so the fuel in tank is too hot. I did measure the pipe temp...
There are on google information about w202 and w203 cdi fuel cooler but I don't find anything about w204 my case...
any link is greatly apreciated
tx
Old Aug 26, 2017 | 11:13 AM
gamma300C's Avatar
Got some feelers out to see where cooler is located...
Old Sep 25, 2017 | 04:24 AM
KirilMacedonian's Avatar
GLK 350
I just changed the Fuel temperature sensor. Had error when checked but showed no error in the car screen. Maybe change that, its cheap(100euros in Europe)
Old May 21, 2021 | 11:42 AM
dan_mac's Avatar
W204
Hi friend,
Did you resolve this problem with your Star?! I have a W204 OM646.811 from 2008 and i'm with the same problem... it hesitates on acceleration at high revs!!
If you can help me i appreciate!!
Many thanks
Best regards
