W204 2008 cutting out along with ESP
Hi all,
Im in much need of some help!! 😩 I have a 2008 w204 diesel and it's been cutting out with the ESP unavailable. I have been reading through previous posts and for what has been recommended.
The ESP unavailable message came up and the car died with an issue to restart. I have replaced the Fuel temperature sensor and the QVC today and still cuts out or stays on idle but runs rough till it dies again.
When I turn on the ignition it seems to be louder and sounds like it has air in the system and and cuts off after 30 seconds ish.
I don't want to keep throwing money into it if it's a easy and logical fix.
It's comes up with errors codes P0088, P0087 and U0106.
Help!!
Help!!
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Those are all useless generic fault codes----what does the MB tester say for your specific engine!----and with diesels is air or fuel---have you tested both your high and low pressure fuel circuit!
I haven't taken it to MB as I'm trying to cut down the cost. I read previous post and last year from Atom-ant it was the QVC, I order the part from MB and still having the same issue. Was just wondering if there was any possible solutions.
