HELP me.. s204 rear subframe front bushes
S204... c250 petrol turbo.
Anyone know if the w203 and w204/s204 have the same subframe?
I'm in the UK and need to replace the front bushes on my subframe... only tool I can find is in America and is VERY expensive.. So in this case I'd rather strip out the rear end...
But I've found a cheaper bush remover/installer in the UK for the w203 which I would happily buy if it's compatible.
Any help would be appreciated thanks
This does not directly answer your question but may help you tackle the work ;
http://tinyurl.com/y99zw2re
I have the means to do the full strip ie, garage plus car lift ramp etc.. it's just if this other tool does fit then it would save a lot of time and effort.
