C300 POWER STEERING MALFUNCTION , ABS, ESC MALFUNCTION.
HI All,
This morning i started my 2010 C300 and received several messages on the dash.
The message read : Power steering Malfunction , ABS, ESC and EBD malfunctions.
What could be the issue? Can someone help me?
*i had a wheel alignment and tire change recently, I'm unsure if these can be related*
breaking light switch. had the same problem view weeks ago. unless your steering wheel is working not normal. good luck hope this helped you. easy and cheap fix. you can even do it yourself just get the part and you can find more then enough instructions online (google,youtube etc)
Why can't they recall these cars? I payed $2000 for the same issue. I AM SO SICK OFIT
HI All,
Later found out my problem was from the hand break.
I put off the car, and depressed and released the hand break several times, and started the car again. I accelerated passed 20Miles without the error coming back.
2010 Mercedes-Benz C300 4Matic Sport
Same Issue
I had the same issue today right after I filled up my C300 2010 with gas. Must be a software issue as my steering was fine. Parked and restarted the car and it went away.
HI All,
Hey brother
HI All,
