Hi all, the light marked in read stopped working for some reason I do not know. Is that something that can be replaced without buying a whole new headlight? If yes what kind of bulb i have to buy pls? thanks
Yes, my C LED was malfunctioning as well and I was able to fix it. You probably don't need to replace the bulb, but instead will need to replace the DRL ballast plate underneath the headlight. You can probably buy this off ebay or from your local dealership.
This is an image of what it looks like, and it is located on the bottom of your headlight. You will need to remove the headlight and change the ballast from the bottom of it.
