w204 with m113 swap
I had a plan on putting the 3,5L m272 when my 3L goes but damn these engines are good, with 220k on it and its yet to leak or burn any oil. But the 3.5 from pre facelift only made 40hp more so im not sure if that would be enough for me and with swapping a 2011+ direct injection 3.5L looks like a pain and might as well save that effort for something more rewarding.
So i have this crazy idea on buying a an older donor car with a 5.4 supercharged engine in it and try to swap it in my 2008 c300, would that be an impossible task ? I gave up on swapping a 6.2 in it because they are ridiculously priced compared to m113s and it also gives me the option of adding 4matic if I desire later on. Are the w204's still too new for swap because I dont see many people attempting such projects on these yet, a few 2jz's swaps and I've seen this swap done on a post once but I cant find it, the fasted c63 quarter mile, they twin turboed a m113 and fitted the 4matic from the previous gen e class into the w204 but for starters id be happy with just a v8 in my w204 for under the price of a c63, possible ?
Its nothing hard really, it took me 4-5hours pulling the transmission out on my driveway with 2 jacks, I did need a transmission jack and some extra hands to fit it back in but its not a hard job. Once it's out, talking the trasfer case is just a few bolts and mercedes sells a transfer case rebuild kit, basicly just all new bearings and seals. I brought my transmission to a local mechanic I know very well and he rebuilds transmissions, he changed those bearing in 2 hours and it was ready to put back in.
Now I would have to take a few pictures but there is a seal, where the axle shaft comes from the front differential to the transfer case that is very hard to put properly, the seal can bind very easily when installing the driveshaft into the transfer case and also the shaft runs right where that seal, so make sure to sand it.
My mechanic guarantied his job and when I put it back in the car, that seal on the output shaft was leaking and the only way to get to it is to take the whole transfer case appart. Now he was lucky he was able to drop the exhaust and transmission mount and lower the whole rear of the transmission just enough to take the transfer case appart and we realized I didnt really had to remove the transmission, the job can be done with the removing the exhaust, dropping the transmission mount and you have enough room to pull the transfer case appart. much easier installing all the bearings with the transmission out but its very doable without removing it if you have access to a lift.
if you do a swap let us know. car-part.com has wrecks but im sure you can find an undamaged engine for a decent price. It should be do-able. C36 4Matic Huh? xD
Wel I'm from canada and 90% of mercedes here are 4matic and this transfer case issue is pretty common. I found local part suppliers that had kits with, its is only few bearings and seals, Also I took the chance but when we took the actually part numbers from the bearing and races, we found a few suppliers, not OEM from mercedes but its the same part so they just label it as theres..You need to get those bearings out and look for the part numbers on each part, they are plenty available and you have to be specialize to work on these tranmissions, lots of little tricks you have to know that why a lot of them would never attempt it.
And yes, Im going to keep an eye out for smashed c63s, they are dropping in value and maybe a 6.2 swap will be challenging enough compared to 5.4 one, it would actually be very easy in comparison ..
so how did it go?
