Icarsoft wont read SRS module
Ok so I was messing around with my paddle shifters which requires the steering wheel to be removed and I accidently turn the key on without the air bag plugged in. Obvious it gave me an airbag light and now im stuck with it, my Icarsoft scanner does not show the SRS module when i plug it in, and it use to because I got the scanner to remove and airbag code the car had when I first got it. My mechanic is able to access the module and delete the code with his xentry scanner but why is my icarsoft unable to read the module when it was able to before and should still?
have you 1) updated the icarsoft firmware and 2) verified you are selecting the correct vehicle model in the icarsoft set up?
the icarsoft i have sees the SRS module on my 204.
Yes it has the latest update on it but that didnt help and like I said, when I first got it I was able to read the srs, now its just not showing up. I just went and pulled the battery and wait a few hours see if that helps.
