C350 2009 error code
Old Dec 20, 2017 | 02:11 AM
Cruel-Merc's Avatar
2009 C350
Hello folks, i plugged in my obd scanner this morning and it threw me an error code P0521 says oil sensor / performance tho theres no CEL light on the dash. Any idea what is it ? Thank you.
Old Dec 20, 2017 | 02:16 AM
Narry's Avatar
Former Vendor of MBWorld
C260
Smile
hihttps://www.youtube.com/watch?v=6TvX1jJ33Bc
check this youtube video
Old Dec 20, 2017 | 02:24 AM
Cruel-Merc's Avatar
2009 C350
Well, i did a new oil change + filter around a month ago and now i check the oil level and its all good, it hit the Max mark.
Old Dec 22, 2017 | 01:33 PM
Cruel-Merc's Avatar
2009 C350
I eventually fixed this issue with replacing the engine manifold due to broken tumble flap Actuator. It had nothing to do with oil sensor, it seems the obd has a different code description from xentry.
Old Dec 24, 2017 | 03:20 AM
Narry's Avatar
C260
Smile
I eventually fixed this issue with replacing the engine manifold due to broken tumble flap Actuator cost. It had nothing to do with oil sensor, it seems the obd has a different code description from xentry.
hi
that exactly how modern cars are all ecu engine abs tcu gear box are interconnected to each other some times it can give you wrong codes
once i get vw golf 6 it had error code saying boost pressure engine sensor have some problems when i scan the whole car it show me back door light is bad
i told my friend to go to vw workshop to repair it do you know they said that needed change the turbo cost 1500 usd car was driving ok not in limp mode
do know when we changed back door bulb ourself and delete the code all is ok no problems cars have become modern mechanics don't understand the electronic nothing
but can say we are very professional
narry
Old Dec 24, 2017 | 02:40 PM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
About wrong codes: I am a bit confused as to the origin of the wrong analysis...
1-was the wrong code due to a bug in Mercedes W204 software on the car-?
2-was the wrong code due to a bug on your tester used-?
3-was the wrong code due to incorrect data sets on the tester you used-?
Old Dec 24, 2017 | 04:38 PM
Cruel-Merc's Avatar
2009 C350
Well, the code (p0521)was the same on both xentry and obd but just different description.
Old Dec 24, 2017 | 05:07 PM
w204_racing's Avatar
C300 sport 2008
A
Old Dec 25, 2017 | 09:40 AM
Narry's Avatar
C260
Smile
1-was the wrong code due to a bug in Mercedes W204 software on the car-? can be one million reasons
2-was the wrong code due to a bug on your tester used-? he is using original xentry which Mercedes offfical tools
this question Mercedes benz Germany can answer
if you want my answer is simple modern cars all is interconnected engine ecu to abs ecu to all other ecu all are connected if one ecu or wiring gets affected it can trigger a code which may not be related to the actual problems
narry
