C CLASS W204 rear right abs fault
hi guys
searched loads and read loads
ive got a W204 2007 c class
got the abs, esp, run flat errors
checked with star this said it was the rear right rpm sensor vidually inspect.
so bought a new genuine part
installed and cleared faules. As soon as i started driving my lights were back on
ive read it could be bearing and abs seals
can anyone confirm this please ?
and if they have part numbers for genuine mercedes parts pls
also read you have to disable SBC module !
any steps and how to’s would be greatly appreciated
thanks
dave
I rang mercedes up and spoke with their parts dept, he informed me there is a ring behind the bearing on mine 2007 that the abs sensor gets its readings from. So i went and bought this and will fit it tomo sometime.
Yes I just checked there is a loose ring. 230 357 01 82 impulse ring
impulse ring
im hoping it sorts it out.
fingers xssed
All sorted guys
thanks for pointers
it was the pulse ring that sits on the end of the drive shaft
ill post pics so anyone who has this problem in future can see
thanks
dave
Old pulse magnetic ring had come off its metal retaining ring
Metal retaining ring
New pulse ring installed
Old pulse ring with magnetic ring split off
thanks for pointers
thanks
dave
Mo420 (05-15-2020)
Hey, how’s it going.
I have a similar problem do any of you guys know the part number for the impulse ring on the front passenger side? I’m planning to replace all 4 sides on a W204 2008 C300 4Matic AWD
