Mo Heat
Old Mar 3, 2018 | 03:30 PM
steve1312's Avatar
Mercedes C200 Cdi
Mo Heat
I have a 2010 C200 Cdi and I have only cold air coming from my blowers, I have replaced the thermostat with no joy but iI have noticed if I rev the engine quite hard when standing i get a small amount of heat but when revs drop it turns cold again.
Any Ideas would be very welcome.
Steve
Old Mar 3, 2018 | 04:09 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
Steve
You have air in your system.You need to bleed the cooling system, try going on an up hill with the engine pointing up off course and the coolant reservoir cap off( Remove it before the engine gets hot), then just hold the rpms at 2500rpms, also keep squeezing the upper and lower radiator hose to force the air out, you will see bulbs in the reservoir when you squeeze on the hoses and I forgot to mention you need to put the heating all the way up with the fan on full blast inside the car as you do this . If that doesn't work then you need to get to the bleeder which is pretty hard to get too (next to the starter on the passenger side head).
Old Mar 4, 2018 | 05:32 AM
steve1312's Avatar
Mercedes C200 Cdi
Thanks for that I'll give that a try.
steve
