Torque Converter issue?
During acceleration and while under load, the car shakes quite badly. I took it to the Mercedes dealership and I was told it will need a new torque converter and lock up solenoid, which will cost me about $4000. With this having so little miles, whats the likely hood that I will not have to replace the torque converter? Will replacing the lock up solenoid fix the issue?
I just purchased this vehicle about 3 months ago and I am not trying to spend 4grand.
Thanks,
Mike
Guys, anything helps. Above is a picture of the diagnosis from the technician. From what I understand about torque converters, I thought the lock up clutch is supposed to engage under high speeds. The shaking occurs during all speeds all gears. So i am a little sceptical of the diagnosis.
There has been various transmission issues on 7g-tronic with 4matic. Cannot really help you...
Having said that, do you know when was the last time transmission fluid was flushed? Transmission fluid should be flushed every 35,000 miles.
I did notice another issue. While in reverse and turning (parallel parking) I am hearing a clunking sound. I’m thinking it’s related, but I could be wrong.
Any thoughts?
The bearings in my torque converter need to be replaced also, my symptoms are noise though so far. I've gone to a fairly reputable indie shop in Toronto Canada and they said the bearings need to be replaced which would cost me $3100 CAD all in to get it done, I haven't done anything yet though.
Yes the part is expensive, but the labor shouldn't be too bad. Look for a rebuilt converter, i'm sure they are out there by now. This repair should be under $2k at an independent shop.
Thanks,
Mike
also you can go to rexbo .eu to buy it cost with replacement not less than 300 eu from sach made in Germany
Any thoughts?
Driving down the highway, steady speed, I gently press accelerator to pass and the car start rumbling. Does so every time.
I cycled through the gears, and it only happens in 6th gear.
I described to a mercedes mechanic and he said the TC needs to be replaced.
Does Bosch make this product or any other quality manufacturers, dont want to pay up for OEM part.
I'd have to look up warranty times but I believe labor should be 6-7 hours max to replace the converter, and I would have no issue with any independent shop that could do it, it's not a special car to work on in that regard. I'm fairly certain there is a reset of the TCC learning that should be done via Xentry/SDS when you replace the converter, but beyond that anyone can do the install for you.
