Lower Control Arm Help
Old Mar 25, 2018 | 04:43 PM
arkim989's Avatar
C320 sport 2003, c300 4matic sport 2013, 2018 GLE63 AMG
Hello,
Has anyone tried this part for 2013 c300? as you can see on the description it says w204 and it looks the same as the one I have on the car right now. Just wanted to double check if this fits our models too. Also are left and right lower control arms are identical?
Thank you in advance.
https://www.ebay.com/itm/NEW-Mercede...f93f%7Ciid%3A1
Old Mar 25, 2018 | 05:22 PM
ItalianJoe1's Avatar
2003 CL 600
A GLK is also a w204, just a 204.9 as opposed to a 204.0/1/3. It should be the same, but I'd have to look it up in EPC and verify for your car versus a GLK. I would think if they were actually the same, they would show C class on the compatibilty list. Check with a vendor like FCP euro, look up the parts for a GLK and your car, see if it's the same part #. See if they show that same Lemforder part for your car.
Old Mar 25, 2018 | 06:51 PM
arkim989's Avatar
Thanks for the fast reply, I checked on FCP EURO they don't have this part. all of their controls arms are for rear of the car, but i did check the sway bars part numbers and they are the same. So i guess this control arm should be the same for c class. Do you know any other good brands of lower control arm that we can buy in USA?
Old Mar 25, 2018 | 08:00 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
https://www.ebay.com/itm/Suspension-Control-Arm-and-Ball-Joint-Assembly-Front-Right-Lower-fits-08-14-C300/302571586995?fits=Year%3A2008%7CModel%3AC300%7CSub model%3A4Matic&epid=1267254607&hash=item4672ac05b3 :g9kAAOSwC81aqzoa&vxp=mtr
Found this and the interchangeable part number is 204 330 80 11 for both the w204 and x204(GLK), if you want to know if something fits from another car, take note of the part number and see if it matches, I know that almost all suspension parts are interchangeable from the GLK to the w204 except the shocks and the thrust arms.
I would definitely recommend Lemforder for any suspension part.
