Daytime running light replacement
Old Apr 4, 2018 | 12:01 AM
Mediii93's Avatar
Mercedes c350 coupe 4matic 2013
Hello can somebody help me so i wanted to change my daytime running light on my c 250 2012 so all i want to know is i already removed the 4 screws and removed the thing .. i see 4 clips to unplugg the light but i dont know how to disconnect the wire from the light do i have just to pull it of or there is a small clip i dont want to breal it there is no video it at all thank you for your answers.
Old Apr 4, 2018 | 08:35 AM
Knightmare69's Avatar
2010 C200 CGI
You cannot disconnect the wire from the light, you can disconnect it from the harness which you should've seen already since you pulled the unit. Yo might want to post a pic of your issue as I've done this several times and it's pretty self explanatory once you pull the unit.
Old Apr 4, 2018 | 05:21 PM
Mediii93's Avatar
Thank you i appreciate you’re answer i did it it was actually easy
