Resealing 4matic transfer case
Old Apr 12, 2018 | 04:02 PM
LandSeaAir's Avatar
2008 W204
Took my car to the dealer to have the transmission fluid changed as it was shifting roughly (probably due to low fluid). 6 months ago had my fluid changed by an indy, so I thought maybe he underfilled the transmission (accidentally or intentionally).
The dealer says they found a "transfer case fluid seep" and that ultimately the transfer case will need to be "resealed" for $1000.
Has anyone heard of this happening on the 722.9?
Old Apr 12, 2018 | 05:57 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
The transfer case out put shaft seal is the most notorious to leak and requires removal of the transfer case to be replaced. When I replaced my transfer case bearing, a mercedes specialist helped me align the seal because it can be tricky since you are working blind. He also told me he does about a dozen of them a year on 4matic models so its pretty common. 40$ seal, rest is all labor removing the transfer case.
Old Feb 18, 2021 | 02:18 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Why did you private mail me?
