no windshield washer
Old Apr 13, 2018 | 12:28 PM
bigrob126's Avatar
2013 Mercedes C250 Coupe
I've had my car almost a year, and just recently tried the windshield washer, but nothing. Is there any common issue related to this? I see fuse number 13 is for washer and wipers....I have wipers. A search gave me nothing.
Grazie!
Old Apr 15, 2018 | 03:54 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Do you have washer fluid?
Old Apr 15, 2018 | 07:18 PM
superangrypenguin's Avatar
A car
Is your battery charged and working on the car? Or is the car on?
Well, gee. LOL
Old Apr 15, 2018 | 07:45 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
Well, gee. LOL
Bahaha, these cars are thirsty when it comes to washer fluid and it warns you when you are low anyways. If you dont hear the little pump when you press the washer button then I would start there as you already checked the fuse. Take the drive side splash guard off and you will see the washer reservoir, along with the pump right in front of you and very accessible. Start by lightly tapping on the pump and see if it starts going,if so then you know the pump jammed up and should be replaced. If not, take a multi meter and check for power and ground as a helper presses the washer button inside, if you have both 12v and a good ground then you know the pump is faulty.
Old Apr 19, 2018 | 09:35 AM
bigrob126's Avatar
Yes....I have fluid. I tried to locate the fuses associated with the front wipers and washer, which are 10 & 13, but all the fuse diagrams I find online, are of a 6 cyl W204, and the engine bay fuse box is a different configuration....that's not helping me. where is my actual fuse chart located?
Old Apr 19, 2018 | 11:10 AM
bigrob126's Avatar
Cool
This thing is working fine....I wasn't pushing the button fully down! Never mind
