P2463 error code dpf w204 c220
I had same issue now p244a fault, i will try to change a turbo pressure solenoid valve first, as I have that fault on dash only when driving on 4th gear.... I had same problem with my renault clio a year ago. So more likely its a valve. I got rid of p2463 fault by activating a dpf regeneration process. was driving aroun 90 minutes, as I have two batteries for my laptop. so while it was on, the process was running. blockage decreased from 400% to 36%... Had a limp mode obviously ...no the engine management light fone , pop up only on 4th gear.... I have the obd tool delphi, so I m resetting that issue every time ffs
