Need Side Marker Bulbs (lamps)
Wifey's car needs a front side marker lamp replaced. I don't need the entire housing, just the bulb. I found a video for replacement that shows you can remove just a bit of the fender skirt and reach in to remove the bulb. The vid shows a different type bulb than the ones I find in online searches for replacements.
Need some help here. Thanks in advance.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Take the bulb out and drive to Armondos auto parts, I am sure they will be able to supply the correct bulb. Alternatively all that info is in your owners manual!!
But thanks anyway. You've been most helpful.
