2010 c350 back up camera
Old Jun 25, 2018 | 11:38 PM
Snoopy415's Avatar
2010 Mercedes Benz c350
Hey guys today I attempted to install a back up camera on my c350 The installation was actually pretty easy but I’m having trouble the screen stays back when it goes into reverse i checked the fakra cable i also connected to the red to fuse #71 stabbing method and the negative to the ground next to the fuse box I double checked everything and it still black any help would be appreciated
Old Jun 26, 2018 | 10:45 AM
exclusivo's Avatar
C300
I did this over the weekend as well but I wired the power to the reverse light so that the camera is only powered when the car goes into reverse. You are probably seeing that black screen because the camera is not being powered. Essentially, you activated the reverse camera, so you are seeing that screen, but since the camera is not on, the screen is blank. It could be the wiring or a bad camera.
Here is the video I watched on the install. I think the guy was originally tapping the fuse but switched to the reverse light. I think tapping the fuse provides continuous power to the camera, even when not it use which will cause it to overheat.
