2008 C300 Engine Noise
Any advice you can provide will be greatly appreciated.
Thank you.
Have a watch at this video, its most likely your air pump. Take the front cover off and listen to it running, surely you will feel/hear it coming from the air pump. These are good quality pumps and 99% of the time just need cleaning, no need to replace it.
Probe the casing of the alternator, power steering pump, A/C compressor, each of the belts, etc. The whining should be immediately obvious once you pinpoint it.
