W204 C300 4Matic: 245/40/18 - NO RUBBING!!!
Old Sep 28, 2018 | 03:54 PM
Andriy242's Avatar
14' E63S
So I found a sick deal and really couldn't pass it up, but after reading every single post ever, everyone says that 245/40/18 on a square setup would rub at the front on a 2012 C300 4Matic Sport. I also thought this would be the case as the 4Matic Sport models actually sit a bit lower so it could be the case.
After installing these, I took a few rips around my area, took them off, marked the parts of the tire with some red marks, and went for another spin. Driving was done on city roads and a bit of highway, and of course full lock turns. Took the wheels off again, and there was no rubbing on the tires, or on the suspension cover at all.
What is this sick deal? Paid $500CAD for new 10/32nd Conti Procontact and New Genuine AMG rims.
I will be following up again later this week just in case, but so far so good.
Here is the before and After setups.
Stock Setup:
225/45/17 Offset 47
245/40/17 Offset 58
New Setup:
245/40/18 Offset 48
Square all around
Old Sep 28, 2018 | 04:19 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Nice deal. You have a slightly higher offset so maybe it balances it out.
I have 235 in the front with 19's and I don't rub, 42 offset.
Old Sep 28, 2018 | 04:31 PM
Gazwould's Avatar
S204 C250 CDI Sport
Good size tyre , width , decent road compliant but low profile tyre , very common on B8 Audi A4 .
Old Sep 30, 2018 | 06:34 PM
25th Car's Avatar
2015 GL450
New Setup:
245/40/18 Offset 48
Square all around
$500 wheels and tires?!?!? That’s a steal. Looks great and good find!
Old Oct 9, 2018 | 01:24 PM
Andriy242's Avatar
14' E63S
Yep $500 for wheels and tires! It was an insane deal. That's also in Canadian, probably like $100 in USD ahhahah.
But Update:
Looks like we might have some rubbing under highspeed load. So if you are going 100+ and hit a big dip, when the car compresses you will hear a bit of rubbing, but not much.
Will be taking the wheels off to check the tires to make sure it's not excessive and post pictures later.
Old Aug 14, 2024 | 10:26 PM
Boston M Benz's Avatar
C300 4matic sport
Hey, so I want to run a square setup, I have the same car. I bought a pair of STOCK rear tires off the same w204 so 245/40/17 et 58 (mine are 17 inch rims) for$200 -- so I want to ask, if I run 10mm spacers on the front, it will not rub on the strut? I tried without a spacer and the tire was touching the strut. With 10mm spacers on the front, my setup will be Front = 245/40/17 et 48 (et 58 stock -10mm spacer = et 48) and Rear 245/40/17 et 47. Do you suggest 15mm on the front or will there be enough clearance on front strut with the 10mm spacer? THANKS! i know this is an old post but if anyone can ask I would be grateful.
