W204 c class
Try using the "automatic setting" and see if it happens again.
I ended up replacing the headlight switch.
ok then Its going in for a diagnostics test today I’ll see what come on the laptop and keep you updated but I’ll bear that in mind what year is your car? Cheers
Im also having issues with my acceleration it hesitates when drive not all the time I’ve replaced the map sensor and fuel temperature sensor any ideas ???
hiya mate.
I’ve Ben recently having trouble with my electrics on my car rear lights front lights ect coming on when car all locked up randomly.
Ive has all sorts of code say malfunction and compas module wth is that I’ll upload pics now
The fix is either replace the headlight switch or leave it in the Auto position.
ok thanks a lot I really do appreciate it I’ve had to take the bulbs out but I’ll leave it in the A position and put them back in it won’t drain anything bein in the A position will it ? I’ve had some codes come back to
I dont know about codes I have no way of checking my car either way dont be concerned with them and next time you are in the shop have the codes all cleared.
Dave
Dave
it’s both my sam modules front ant rear that have codes.
I’ve had my 02 checked
does anybody know what it could be please it’s pissing me off
Hi, did you manage to find the problem with this. I have the same issue along with the Fan running constantly when the engine is on
