2014 C250 Command, Radio Screen two shades of grey
black 2014 c250
How are you guys doing? I am having an issue with my radio screen. First I thought it’s the LCD but I switched between different functions like Navi, setting etc. and I don’t see the color difference there. Looks all normal. My headlights are set to automatically turn on and it works fine. I switched bitween daylight, night etc. and still the same thing. The car was sitting in a garage over night and had the same problem this morning. Did I change a setting somewhere? Do you guys have an idea?
I don’t want to drive all the way to the dealer if it’s just a setting.
Thx
I am guessing you have the display set to the night version. There is a day, a night and an automatic. Not sure what the exact verbiage is as it has been a while since I last did this.. You change that in the display settings. Look in your owner's manual and it will explain the procedure.
black 2014 c250
Thank you for your reply! I already checked those settings. Right now it’s set to automatic. The bottom is always lighter then the top. I switched between the settings. All the other screens Navi for example looks normal
