correct transmission fluid
Old Nov 17, 2018 | 07:24 AM
Lowufo's Avatar
2008 C300 4 matic
Hi All
about to change my tranny fluid and want to make sure I have the right fluid !!. I have a 2008 c 300 4 matic which I believe has the 722.9 ,7 speed tranny. I bought a kit on amazon of Meyle ATF-lll-H fluid with gasket and filter. specs. say.......mb 235.71,236.6,236.9,236.10,and 236.11 along with a host of other applications IS THIS OK TO USE IN THIS TRANSMISSION ?????
THANKS IN ADVANCE FOR ALL THE INPUT !
Old Nov 18, 2018 | 05:33 AM
alecmascot's Avatar
W204 C220CDI 2011
https://bevo.mercedes-benz.com/bevol..._en.html#close
Old Nov 18, 2018 | 10:57 AM
xsever's Avatar
2012 C300 4MATIC Sport
Originally Posted by Lowufo
Hi All
None of the Meyle ATFs are approved. For your transmission, you need MB spec 236.14 (red fluid) which is found here: https://bevo.mercedes-benz.com/bevol...236.14_en.html
Only the ATFs listed in the link should be used.
Old Nov 19, 2018 | 06:06 AM
dboyrusky's Avatar
2019 GLC300 4matic, 2019 C300 4matic, 2018 C300 4matic, 2009 C300 Flex, 2004 C230 Kompressor
No good. Above post is correct. You need fluid with 236.14 approval.
Old Nov 19, 2018 | 11:06 AM
nelson g's Avatar
C300 4matic
Amazon is not always the best deal nor due they always have the right product. Buy from a real auto site so you know the product will work for your application.
https://www.fcpeuro.com/
https://www.ecstuning.com/
I use both these companies and have never had a problem or was sent the wrong item. Do I pay more, not when you figure in you don't have to deal with returns and the job goes well.
Nelson
