Front pad replacement
Old Nov 21, 2018 | 10:55 AM
superangrypenguin's Avatar
A car
As I am in the process of cheapening out on repairs (you guys all know why), one of the things I may have to do in the short term is to replace my front brakes (pads only, not rotors as I'm cheapening out).
As per various Youtube videos, it seems that folks usually put the car on a hoist so they can turn the rotors/pads towards them in order to loosen the bolts. Well, I don't have access to that. Everything looks straight forward, but my question is, can you replace the pads while the steering wheel is pointed directly forward?
Old Nov 21, 2018 | 01:58 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Yes. I don't have a lift but use the backup Jack and do 1 side at a time. No need to turn wheels, as I've done both sides at once.
Old Nov 21, 2018 | 08:31 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
I have two jacks and always jack up each side so its leveled and easier to work on. If you only have one jack, its not necessary to turn the wheels but it does make it easier so just turn the wheel before you jack it up and that should make it more accessible.
Old Nov 22, 2018 | 10:30 AM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
There is a lifting point in the center of the front crossmember, so a single floor jack can get the front end up off the ground.
Old Nov 22, 2018 | 03:44 PM
Right, I forgot about that jack point but the sport model bumper is way to low to reach it, even with a low profile jack. I guess you could drive it up ramps and then jack it up.
Old Nov 23, 2018 | 09:49 AM
A car
Anyone know what the torque specs are for the nuts/bolts on the calipers?
Old Nov 24, 2018 | 09:24 PM
Just204's Avatar
Mercedes w204 4matic sport
snug them and then tighten just a bit more, OEM pads come with new pad bolts that have lock tite on them so they should stay fine, they are not heavy duty and are one time use so some common sense helps when deciding how tight to make them. I would remove the caliper brackets and clean the pad contact points thoroughly so the pads don't hang up over use, also use a little lube on them as well. caliper bracket bolts just get them real nice and tight, you won't break those bolts. I have never found the need to torque bolts for brakes lol.
