80W Bulbs
Some people say they run 100W fine, I'm confused.
My friend has some halogens which are whitish/blue and great output but we can't find the Osram model.
I'll just use them for high beams then.
55W to 80W is only a 25W difference - significant, but it seems like only those going from 35W housings to 100W
have melting problems.
I can be the guinea pig. Otherwise it gives me an excuse to get those new w205 style headlights lol.
They have a large selection of bulbs, but the thing about this site is that they are very knowledgeable about their products. They have the following bulbs: The Vosla H7 +100, German Vosla H7 +120 bulb, Osram NightBreaker "Unlimited" Ultra High Output +110% H7 , The Philips Xtreme Vision lamps. I use the Osram and they work great. Take a look and e-mail them they respond and answer your question I have used them for years.Nelson
I tried one pair of H7 LEDs found the right side was okay but left side had a bad beam pattern with some blind spot. The LED I tried is two sided (two LED chips per bulb).
I found there are '360 degree" LED bulbs, three even four sided LED chips. I wonder if they are close to 'perfect', non-blind spot, halogen like beam patterns. Physically the LED chips are placed around the center, not like halogen filament which is in the center.
I have to try to see the result. It could be a waste of money.
With HID atleast the hole is covered.
I'll let y'all know how this goes.
There are ones that heat up less but have less output.
Normally they do run cooler but I don't know if it's the same case for these.
I will try to run a quick test this weekend, halogen vs LED. In car test is difficult. I will find an enclosure kind of similar to the headlight housing.
I took several small video clips of OEM light output, bulb structure, color, light throw, Phillips Crystalvision bulb structure, Osram bulb structure, color, and now all that is left is to record the cutoff and nighttime visibility. Then I'll have to do a commentary to explain my results, although idk when I'll be able to get to that.
Initial thoughts: cool beans
If you mean for the bulbs I just got, soon!
Once that is done I can put everything together and come to a conclusion
Hopefully it does not fail me
Therefore, the only concern is how to find a true '360 degree' light beam LED bulb, or 'no shadow' light described by many Chinese manufacturers. Some 2 side chip design claims it is 360 degree, others have 3 or 4 sided chips. I can't try one by one to find a good set; it could waste money.
