brake lights on after EIS problem
This issue is getting me frustrated as I swapped out the brake switch but still no joy. If I disconnect the brake switch (magnetic type not spring) the rear brake lights work fine as they go off and on with the push of the brake pedal. The only issue with leaving switch disconnected is it throws up ESP and runflat errors on display cluster.
any one have any idea what went wrong or how I can possibly fix this problem.
