ABS and Power Steering Error
I washed the car yesterday so maybe I got a wheel speed sensor wet? Although idk how that would affect power steering. I did just do ESL repair but had no problems yesterday, so it can't be that...
Any ideas? Every thread on this has a different answer.
Battery isn't low, as its brand new.
EDIT: When I did my ESL, I may have failed to plug in the brake light switch properly; I will have to check tomorrow.
The first time these lights came on, I was very close on buying a new ESP module but as I arrived to the part store, the lights came out. I remember having the battery disconnected not long before that so i know what caused it now.
Don't throw parts at it and just drive it for a week with the lights on, surely someone with a STAR diagnosis system can probably calibrate it but from my experience, it can do it by itself. Strange for the power steering error, however, mine was only ESP/ABS that was malfunctioning.
Also it seems like 5 other people are having this same problem at the same time and no results...
. have the exact same issue and it's driving me nuts as unable to fix the error
Mine would act up once every few months and then would work again for a while, very annoying. I found a used low mileage ESP module with the same part number and coded it in, hasn't given me trouble since.
You need a scan to see what comes up. It could be the module. It could also be other things.
See this video as it covers the possible ABS error culprits.
