Setting up garage door button
Old Mar 30, 2019 | 05:53 PM
glj12's Avatar
C300 Sport
Question Setting up garage door button
I have a Liftmaster 8550 I believe, and I have a Mercedes C300 2008. I am having a lot of trouble getting past step 3 as per the directions on homelink: https://homelink.com/program/instruc.../0/0/usenglish as well as the same step in the Mercedes manual for my vehicle. This step is when you press the desired button to program and the garage door button on your remote. The directions state that the indicator light will flash slowly and then rapidly by my car's rear view mirror button, but it never flashes rapidly. The light continues to flash steadily, indefinitely.
Any help or advice to get past this step? I've tried pressing my garage door's "Learn" button during this phase as well with no such luck.
Old Mar 30, 2019 | 08:33 PM
CJG's Avatar
CJG
2016 C300 4MATIC
There are videos. You have to follow the directions to the “t”.
Are you pressing the garage door control button when you do it?
do you press and hold the button on the garage motor until the light changes? You can’t just press it once. You have to hold it a second.
You’re not alone. I get frustrated every time I have to do it.
Old Mar 30, 2019 | 08:38 PM
timlippold's Avatar
2008 C300 Sport
Does it work on other cars? Make sure your remote is pointed at the sensor. Try many angles. Also confirm your opener is compatible as there are some that are not.
Old Mar 30, 2019 | 08:51 PM
CJG's Avatar
CJG
2016 C300 4MATIC
And you want the video with a balding German sounding guy. Some videos I’ve seen are incorrect.
Old Mar 30, 2019 | 10:00 PM
glj12's Avatar
C300 Sport
Yes, I watched that same video. I hold both the targeted button and the garage door opener, simultaneously, and do not let go. However, the flashing light remains slow and constant, and never rapidly flashes.
Any other thought given that I cannot get past this stage?
Old Mar 30, 2019 | 10:55 PM
CJG's Avatar
CJG
2016 C300 4MATIC
Does your garage door opener actually open the garage? It may need to be programmed
Old Mar 31, 2019 | 08:34 AM
glj12's Avatar
C300 Sport
Yes, it does.
Old Apr 1, 2019 | 06:45 PM
glj12's Avatar
C300 Sport
Thoughts, anyone?
Old Apr 2, 2019 | 10:52 AM
abqhudson's Avatar
2014 e350
It will work. Follow the manual exactly, when you think you are finished - go to the next step for rolling code. VOILA.
Old Apr 2, 2019 | 06:45 PM
glj12's Avatar
C300 Sport
So the answer is that I must be somehow doing it incorrectly, but no indication as to what specifically? I don't think that is very helpful. Can anyone suggest what /might/ I be doing wrong, given my initial description in my post?
Old Apr 2, 2019 | 07:11 PM
lkchris's Avatar
'10 CL550, '12 GL550
Should be a video at mbusa.com
Old Apr 3, 2019 | 09:20 PM
glj12's Avatar
C300 Sport
The video on the site was not for my version, as my car is older.
Again, any actual helpful comments instead of suggesting I try harder? Letting me know what I /could/ be doing wrong in the OP would be more helpful.
Old Apr 3, 2019 | 11:04 PM
raymond g-'s Avatar
99 E320
how about this? performing the handshaking using the garage door opener's instructions...but using the
MB buttons as if they resembled the remote.
I have a Chamberlain opener and a 1999 E320. I ignored MB instructions and used this method:
reach up and activate the opener's learn mode (flashing LED on opener)
reach down into car and press the mirror/opener button (opener LED changes from flashing to steady, then out)
that pretty much did the trick with my E320 as well as about 5 key fob remotes which I have for my cars and motorcycles.
(hope I am understanding what you're trying to do from my keyboard. I will reread the homelink text again)
Old Apr 4, 2019 | 01:47 PM
white46's Avatar
08 C300
You need Liftmaster 855LM Homelink Repeater Kit.
Older vehicle like w204 Homelink is not compatible with newer technology used in garage door opener.
Old Apr 4, 2019 | 03:30 PM
glj12's Avatar
C300 Sport
Oh my goodness, thank you so much. And thank you too, Raymond for putting in effort to trying to solve my problem!
Old Apr 4, 2019 | 05:51 PM
white46's Avatar
08 C300
No problem.
Just like you, I was so frustrated with homelink until found existence of 855lm repeater kit.
Old Apr 4, 2019 | 07:46 PM
abqhudson's Avatar
2014 e350
Try again. I note that there is no step 3 in the owners manual and I repeat my previous advice with the following addition - I'm talking about the Mercedes Owners Manual. I recently purchased a 2008 Mercedes C300 and had no problem programming my garage door opener in the car as per the advice in my previous post. The manual is available online from Mercedes Benz USA. Best of luck.
Old Apr 5, 2019 | 09:02 PM
glj12's Avatar
C300 Sport
It looks like you missed a bit of the conversaion here that happened after your last reply. It was resolved by purchasing a HomeLink repeater that works with older cars, for newer garage doors. My garage door is fairly new, which is why it did not work with my vehicle.
Either way, thanks all for all of your help!
Old Apr 27, 2019 | 07:10 PM
mikesho's Avatar
c300 4matic
garage door opener
Dealer sent a tech to my house to program it . He had to come twice . He couldn't get it to work the first time . It's a service that they do for no charge .
Old Mar 8, 2020 | 08:53 PM
sack5000's Avatar
2015 AMG C63 S
I have the repeater in a 2015 C class and it will not work does anybody have specific instructions on how to get the repeater to work? thanks in advance, appreciate it. By the way, I’ve had six Mercedes-Benz vehicles and never had a problem until I replaced my garage door opener, imagine how many repeaters they’ve sold at 30 bucks each and not supplied any reasonable instructions to come with the device... thanks again
