Clip inside cup holder broken
Old May 2, 2019 | 11:41 PM
Amaral0139's Avatar
C300 4matic sedan
Hi everyone
I can’t seem to find a solution on purchasing a clip that was broken inside my cup holder. Anyone know where to find one without buying the entire console which I’ve been told by the dealer.
thank you
Old May 5, 2019 | 01:32 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
Are you sure your clip is broken inside, not just fell?
One of my clips was a bit misaligned and was rubbing the cup holder housing. I touched it and it fell inside. Youtube shows how to remove the center console to expose the cup holder. Mine is never removed so the trim piece is very tight. I am afraid of breaking anything so will not do it now. When time comes I will replace the control knob shaft with a metal one although it is still stock piece now.
Old May 6, 2019 | 11:32 AM
C300CA's Avatar
I couldn't wait so tried taking trim pieces off. It was not as difficult as I first thought until the step to disconnect the control knob cable. Youtube video shows it very easy but I can't seem to access the connector. Maybe the cable has enough slack so I can lift the whole cup holder assembly just enough to reach the clip underneath. I will try it another time.
Old May 6, 2019 | 10:17 PM
Amaral0139's Avatar
C300 4matic sedan
Thank you guys for the feedback in my case it wasn’t in there it’s actually broken and some how disappeared. I can’t find anywhere that sells a separate clip and guys parting out their cars want about 50 dollars for one clips ( pretty ridiculous)
Old May 7, 2019 | 10:14 AM
C300CA's Avatar
For 50 dollar a clip, I would rather miss it. It just doesn't look perfect with one missing. Or, 3D print one.
Old Jun 21, 2020 | 12:06 PM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
I had the same problem and only needed one clip. I'm selling left over Mercedes Cup Holder Clips on eBay.
You can also DM me.
Old Jun 28, 2020 | 08:58 AM
dboyrusky's Avatar
2019 GLC300 4matic, 2019 C300 4matic, 2018 C300 4matic, 2009 C300 Flex, 2004 C230 Kompressor
i bought 4 pieces used on ebay for 20$
Old Oct 16, 2021 | 02:49 PM
AG03's Avatar
2011 c63
I need to replace a missing one on my console, I also ordered the clips.
Does the console need to be removed to replace these clips?
I quickly attempted with just the plastic trim cover removed, but can’t seem to get the spring to sit correctly.
Any tips?
Old Jul 22, 2023 | 03:33 PM
mrsnak's Avatar
2011 C350
So here we are in 2023, and I've found zero info on the web how to simply replace the clips. One of the most frustration small jobs I've tried in a while. I removed to trim cover to see if I could get at it easier, but still not seeing it. I'm trying to see how the spring is positioned, and am not getting the right tension once I clip into place.
Trying to get this in.
Old one in place.
Old Jul 22, 2023 | 03:37 PM
You have to remove the console @mrsnak
https://www.pelicanparts.com/techart...le_Removal.htm
Old Jul 22, 2023 | 04:52 PM
mrsnak's Avatar
2011 C350
Yikes, afraid of that. So gear shift cover needs to come off as well?
