Rear Rotor Recommendations? Difference Between Brembo and PowerStop?
Old Jun 19, 2019 | 11:29 AM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
Question Rear Rotor Recommendations? Difference Between Brembo and PowerStop?
Presently, I need to change the rear rotors but I want to go with drilled.
This is a daily driver with a lot of city driving. On the highway, I'll do 80 to 85. Standard driving...
I'd like a little more stopping power and to change the look.
I've looked at Brembo (drilled) &
Power Stop Power Stop
(drilled and slotted)
Brembo is $200 vs. $100 for PS
  • Brembo is UV coated which is certainly better environmentally and exposure wise.
  • Power Stop is zinc coated and states "Reversed engineered from OEM samples using G3000 grade iron".
Q 1 So they're both high carbon?
Q 2. How many pistons on the rear caliper? I read there is only one which seems hard to believe...
Q 3. Safe to assume the Brembo is better quality at high speeds? Say over 100 MPH?
Any insight is appreciated.
Old Jun 19, 2019 | 06:17 PM
25th Car's Avatar
2015 GL450
I am just going to throw this out there based on your comments and questions. Both are good rotors, however, I believe with your concerns, you should be looking at what type of brake pad you want to use more than the rotor.
When I contacted FCP Euro and told them I wanted to track my car a couple of times a year for a trackday here and there, they told my to go with OEM replacement Zimmerman rotors (coated, will not rust) and EBC Yellow pads.
Now, obviously if you want to change the look, then you need to have someone else pipe in for their recommendations. But for stopping power, I believe the pads outweigh the rotors.
Hope this helps.
Old Jun 19, 2019 | 06:26 PM
Hope this helps.
I'm going to use the
OEM ceramic pads OEM ceramic pads
. I'm not tracking the car but if I were yeah, I think you need something with more bite.
Old Jun 20, 2019 | 12:41 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Oems are semi metallic as far as I remember....
I went with akebono rear pads and Zimmerman rotors and the stopping is really good.
Old Jun 20, 2019 | 01:04 AM
You're correct. OEM is Semi Metallic. The driving conditions are not typically extreme. Although this year, Los Angeles got a ton of rain. I'm happy with them
Was just reading Bridgestone's overview on pads.
