Engine code P0008A?
Old Jul 12, 2019 | 03:38 AM
Sticktalk's Avatar
2013 c250
Engine code P0008A?
So I was driving my car and hit the gas as I was trying to pick up speed , and the car shifted funny and the check engine light came on and I lost power, RPMs wouldn't go too high... problem has happened a few times and the check engine light turns off after a few cycles of driving, and back to normal. I got the code pulled at a local autozone and they came up with the error code P0008A- low pressure fuel system pressure too low. What's going on here
Old Jul 12, 2019 | 04:09 AM
xsever's Avatar
2012 C300 4MATIC Sport
These cars are known to suffer from a failure in the high-pressure fuel pump. Do some research on it and you will find a lot of threads on it. This is likely what is happening with your car.
Old Jul 12, 2019 | 04:17 AM
Sticktalk's Avatar
2013 c250
That's what I was worried about, as I've heard the HPFP fails often on these cars. It seems
like a complicated fix for myself, and costly at any mechanic. Is there anything serious that can arise from this issue? If I don't punch it, then it never acts funny, but it can steadily pick up speed merging on the highway and when I need to go. Sometimes I can accelerate quick and it'll be fine, other times
not so much. Thanks for the info.
Old Jul 12, 2019 | 06:58 PM
The Critic's Avatar
none yet
A P0008 refers to the low-pressure side of the system. Assuming the pressure sensor is reading correctly, get the freeze frame data and tell us what the fuel pressure reading was. I think 5 bar is about right.
Your problem may not be with the high pressure fuel pump.
Old Jul 13, 2019 | 12:09 AM
Sticktalk's Avatar
2013 c250
Would I have to basically get the code read by a Star system at an MB dealer, so it gives me more details? Thanks for the info, I'll work on getting that
Old Jul 15, 2019 | 04:13 AM
The Critic's Avatar
none yet
Most decent aftermarket scanners should be able to provide you with the freeze frame data.
Old Sep 14, 2019 | 01:05 PM
Sticktalk's Avatar
2013 c250
Update: So I popped the hood just to look and noticed there was a hose that was kinda ripping. It was the little hose on the air intake hose I believe? I never got the codes read by a more accurate reader, nor did I get the freeze frame data.I decided to buy the hose for $20 on ebay and replaced it myself. The old hose basically crumbled when I touched it (POS quality). The car feels much better and doesnt sputter when I hit the gas now. No problems since!!
Old Oct 17, 2022 | 02:44 AM
jb123mb's Avatar
GTR
Why would a damaged hose give a fuel pump error code?
The reason i ask is that i have the same code P008A00, do i search for a pump issue or a hose issue or both?
Old Oct 21, 2022 | 09:33 AM
JRL3GEND's Avatar
C63
Hey Man did you ever figure out the problem?
Old Oct 21, 2022 | 09:37 AM
jb123mb's Avatar
GTR
Not yet.
Old Jul 6, 2023 | 10:52 PM
djnunez27's Avatar
2013 MB C250
I have the same exact issue as well, I popped the hood and my fresh air intake was ripped. Order the part for $30. I hope that will fix my problem 👍🏼
