Crank no start no lights no gas gauge?
Old Aug 12, 2019 | 06:28 PM
Guyver96's Avatar
clk 320
Hello everyone.... Just to give you some back story in case its needed...
About a week ago the battery died. I got the car jump started and drove my unhappy Ars back home. I had a yellow top battery from my 03 vw turbo s so I put that in the car turned on and I've been driving since till today. I got home I parked the car and that is it... I get in it cranks and cranks but wont start. I don't have any lights what so ever nore inside or outside trunk wont open keyfob wont work dash shows good battery V at 12.7 unless this car requires more than that and when I turn it over it comes down to about 12.1 sometimes 11.6 was the lowest but now I'm concerned I'm just draining the battery every time I try to crank it on. soo... here's what I don't have..
no lights in or out
keyfob wont work unless its on the handle sensor
trunk wont open
gas gauge wont move up and i have a full tank or 3 quarters of a tank almost full.
pressing the brake does nothing for the rear lights
gauge lights up normal not showing any messages
I don't have a scanner ill be ordering one soon specially after this.
Any thoughts, Help, suggestions or if you want to know something i may not have mentioned pls feel free to ask i have about a week before i need the car up and running so hopefully i can get some help thru here and gets this thing back on the road again. thanks in advance hope to hear from someone soon.
Old Aug 15, 2019 | 07:27 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Was the key in ignition when you jump-started the car?
Old Aug 15, 2019 | 07:29 AM
Guyver96's Avatar
clk 320
Yes first click I was looking at the voltage read out and as soon as it showed 13 I cranked it on.
I got it running again, tho the rear Sam power connecter somehow got disconnected completely. How I have no clue how maybe someone tampered with it before I got the car and it finally just came off. I'm still babying, it I've got AAA so I am staying within towing range lol... I learned about the Sam unites after first posting Just don't want to delete it in case I still have the issue or someone has a similar issue. Found it odd it would crank just wouldn't start.
Old Aug 17, 2019 | 01:42 PM
Guyver96's Avatar
clk 320
On another subject does anyone know if the w203 has a Front sub frame Bushing style mount like the rear or is it just solid bolt to car?
Old Aug 17, 2019 | 04:48 PM
Alfadude's Avatar
2012 C300 4Matic
Best to post that question in the W203 section. This is the W204.
Old Aug 17, 2019 | 09:14 PM
Guyver96's Avatar
clk 320
Oh my bad didn't realize I posted in the w204. Sowwy
