C250 Rough Idle in Reverse
Old Aug 26, 2019 | 11:05 PM
Roush2fast's Avatar
2008 C300
Hello I am trying to track down the cause of a rough idle. The idle is rough enough to be felt when sitting in the driver seat. It gets even worse when the car is put into reverse and even more worse when the wheels are turned while in reverse.
I have no codes and have done some maintenance including plugs , plug seals , valve cover seal , throttle body clean and replaced the turbo mini tube on intake tube. I have checked for vacuum leaks visually and have not been able to find anything. The car drives very well and has no issues other than a rough idle. I was going to clean the MAF but I cannot find one. I see the map and boost but no maf.
Tomorrow I will put my carsoft on data stream and check fuel trim and 02 sensors. Does anyone know what the value range is for a functioning b1 s1 sensor ?
Any additional ideas would be greatly appreciated. This is one I cannot figure out.
2013 sport 60k
Thanks.
Old Feb 1, 2022 | 12:17 AM
chabbs93's Avatar
c250 W204
2013 sport 60k
Thanks.
well it’s been two years+ did you track it down? Going through this with my 2012 right now. Just poor general idle
Old Feb 1, 2022 | 01:31 PM
AAIIIC's Avatar
2014 C250 Luxury
Click on their username, click on "View Public Profile" and you will see "Last Activity: 11-10-2019 05:00 PM". Probably not going to get a response.
Old Feb 1, 2022 | 02:45 PM
chabbs93's Avatar
c250 W204
i appreciate the tip!
Old Feb 2, 2022 | 09:02 PM
sege's Avatar
2012 C250
My rough idle turned out to be a cracked Turbo hose
