P0073 Bizarre issue
CEL (P0073)
Outside temp is offline
Radiator fan is running on full blast all the time
High beam icon is always illuminated on the dash, however the low beams are on and in-fact the high beams do not stay on.
Parking brake light is always illuminated regardless of the actual status of the brakes.
Blinkers work but do not illuminate on the dash.
A/C stopped blowing cold air.
Alarm went silent. Doors lock and unlock but no panic and no beep beep.
the front end of the car does not communicate with the back end of the car
no in cabin lights
These symptoms would come and go. Every-time the outside temp went offline the symptoms would arise; once the outside temp kick back online everything works just fine.
I replaced the ambient air temperature sensor hoping that it would fix the problem, and it did for 5 min. Then, it stopped working again. Tested the battery and it was good, also the wiring going to the sensor looks fine. Does anyone know what the next step might be?
UPDATE: I got the alternator tested and the shop said that it was bad. specifically the voltage regulator. did anyone has similar trouble due to a bad alternator, and do yall know if there is a DIY guide out there.
any input is appreciated. Thank you!
CEL (P0073)
is there any new news with your car ?
have you tried what I did?
also nowadays In the morning the car goes back to normal and after an hour of driving it goes back to the same problems.
I could not find my ambient temperature sensor in its location. Maybe because the previous owner changed its location.
