Code p0457
Old Oct 4, 2019 | 06:51 PM
s02g500's Avatar
2002 g500
Code p0457
I have a 2012 c250 and I keep getting a p0457 code “loose gas cap” I’ve replaced the gas cap with a oem one from the dealer and cleared the code in a few days it comes back what else could it be ? Has anyone had this issue ?
Old Oct 5, 2019 | 12:34 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It could be a crack in the fuel sender/pump covers on top of the tank. Remove the back seat cushion and the access plates and check for fuel leaks (or signs of previous leaks) there.
Old Oct 6, 2021 | 12:10 PM
DaveDammitt's Avatar
2014 C250 Sport
Resolved on 2014 C250Hiya. I know that this is an old thread, but this is what comes
I know that this is an old thread, but it comes up when searching Google for "Mercedes P0457".
I kept getting 'Gas Cap Loose' messages. I was 97% sure that the gas cap and seal were fine, so I added another o-ring under the original. No go. Bought a new gas cap (opened carefully and kept the receipt) . Also no better. Got to snooping under the hood, and it turned out to be a broken hose to the Vapor Canister Purge Valve. Used a heavier piece of tubing that wasn't pre-made as an elbow. Took 5 minutes, after weeks of frustration. The part in question is at the front of the engine on the driver's side (US), right beside the windshield washer reservoir. Says 'MOT' on top of it. Engine light cleared before I even drove the car. Hope this helps someone, now, or 5 years from now.
