Battery replacement
Old Oct 13, 2019 | 09:15 AM
twiemann's Avatar
C350
Battery replacement
Do I need to back up the computer with 12volts to change the battery and if so, I need information on which battery saver cable that can hook into the computer to purchase.
Old Oct 13, 2019 | 08:05 PM
house67's Avatar
W204 C300 4-Matic
You should be fine, you may just lose radio presets and have to re-sync your windows.
Old Oct 14, 2019 | 02:30 PM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
In my case they just disconnect battery, replace it, reconnect, alarm went off, reset all ok.
Old Oct 15, 2019 | 09:40 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
My 2009 C300 4Matic....replaced the battery the "old" way w/o battery tender in place. Lost nothing.
Old Oct 17, 2019 | 12:27 PM
Jonesy65's Avatar
2007 C 300
I’ve done the same thing and nothing bad has happened. You’ll be fine with swapping your battery
Old Oct 20, 2019 | 04:32 PM
th1ef's Avatar
Car
There could be a back up battery in the trunk. Needless to say I’ve had to reset my VIM adapter a few times when it glitches by disconnecting the negative terminal. Never lost anything.
