2011 w204
Old Nov 30, 2019 | 03:46 PM
SJw204's Avatar
C300
2011 w204
I have a 2011 c300 sedan and while replacing a headlamp bulb I lost the wire clip that holds the bulb. The dealer will only sell the entire headlamp assembly and no luck at salvage lots/used parts places.
Any suggestions? The light kinda just bounces around.
Old Nov 30, 2019 | 05:10 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
I would try to buy a piece of spring wire from hardware store and bend it towards the stock spring clip. Shape does not need to be exact as long as it can hold bulb securely.
Old Nov 30, 2019 | 05:17 PM
MBpippo's Avatar
2013 C204 C250 Coupe
Typical, and it probably costs $700. Most dealer parts cost $700! Spring wire as C300CA suggested will do it.
Old Nov 30, 2019 | 05:25 PM
Gamer_M's Avatar
Mercedes-Benz W204 C250
I've done my headlight bulbs yesterday, and almost lost it myself. I've accidentally drop it inside the engine bay and have to fish it out(used a metal clothes hanger btw) . If the clip is inside the bay, I would suggest try to fish it out if you can. But if not, I found some spring wires online. Take a look:
Amazon Amazon
Old Nov 30, 2019 | 05:41 PM
MBpippo's Avatar
Even if the Amazon ones are not an exact fit, you’ll be able to bend to fit with 2 pairs of pliers.
Old Nov 30, 2019 | 06:01 PM
SJw204's Avatar
C300
Thank you I’ll try that
Old Nov 30, 2019 | 06:04 PM
SJw204's Avatar
C300
Wow If I was not convinced that amazon sold EVERTHING, I am now! Thank you
Old Nov 30, 2019 | 06:37 PM
5by5's Avatar
2011 C300 Sport 4matic, 2005 C240 4matic, 2003 C230K Sport, 1999 C230K Sport, 1969 220D (first car!)
Find somebody with a parts car on Craigslist or visit a junkyard.
OEM part is probably only $1 at your local Pick-Your-Part. Bring your other one, there’s a good chance the parts interchange between models and years.
You could even pull one off a car with front end damage and broken headlights.
5
